Author Topic: 93 NH750 Scrambler Build (UPDATE)  (Read 10594 times)
Offline Chris R
  • Bike: 93 CB750
Re: 93 NH750 Scrambler Build (UPDATE)
« Reply #25 on: April 22, 2016, 02:48:21 PM »
I have that reversed.  The R6 stem is shorter that the stock stem.
Offline Chris R
  • Bike: 93 CB750
« Reply #26 on: April 22, 2016, 02:56:20 PM »
No.  I really screwed up on the tires.  The front in the pics is 120/70-17.  I swapped that out with the 90.  Overall diameter is super close now. Twinduro tires.
Offline alwhite00
« Reply #27 on: April 23, 2016, 03:42:39 AM »
I got it, So a longer stem is required.
Offline Masty
« Reply #28 on: April 25, 2016, 08:02:50 AM »
Very cool build. Thanks for sharing!
Offline Chris R
  • Bike: 93 CB750
« Reply #29 on: May 08, 2016, 02:39:00 PM »
Offline Chris R
  • Bike: 93 CB750
« Reply #30 on: May 08, 2016, 02:41:06 PM »
Offline tscott
  • Bike: 1991 NH750
« Reply #31 on: May 11, 2016, 11:31:54 AM »
I like it. What part# are those K&N filters? Is the side-to-side clearance okay?
« Reply #32 on: May 11, 2016, 04:09:52 PM »
The K&N logo is stamped stamped on the ends of the pod filters.
Offline alwhite00
« Reply #33 on: May 11, 2016, 06:36:09 PM »
anxiously awaiting how the pods work out.
Offline SoloVoyage
  • Bike: 1991 nIGHTHAWK
« Reply #34 on: May 11, 2016, 09:34:22 PM »
+1. I love the look of pods and I'd love to covert the air filter space to something useful but, I've heard nightmare stories about the pods too much.
Offline tscott
  • Bike: 1991 NH750
« Reply #35 on: May 12, 2016, 11:07:03 AM »
 nice1
obviously. asking about the part number. like, it looks like an RC-0984 but i'm wondering if he found ones that are narrower to accommodate the carb spacing.
« Reply #36 on: May 12, 2016, 01:16:11 PM »
 nice1
Sorry -- I misread your post as two separate sentences at that point.  I.e. "What part #?  Are those K&N filters?"
I've always wondered how pods on bikes handle wet weather.  Seems to me like that would be a potential problem.
Offline Chris R
  • Bike: 93 CB750
« Reply #37 on: May 14, 2016, 09:03:18 AM »
RC-0984
Offline Chris R
  • Bike: 93 CB750
« Reply #38 on: May 31, 2016, 08:17:26 AM »
Hey Guys, I just wanted to give an update.  Things are coming along pretty well.  Wiring harness is consuming a lot of time.  New risers and handlebar.  Fitting a new Acewell speedo.  Got the exhaust on.  Fabricated a rear pan/wheel well.
Acewell Speedo
Speed Sensor
Offline Chris R
  • Bike: 93 CB750
« Reply #39 on: May 31, 2016, 11:53:52 AM »
Also forgot to mention new extended braided brake lines.
Offline Adventurer
« Reply #40 on: May 31, 2016, 06:41:55 PM »
Look'n GREAT! My '92 Nighthawk CB750 is pretty much all OEM at the moment (recently purchased, via Craigslist), but I'm think'n about wrapping the same section of pipes as you have, in black. Any tips or downsides?
Every day is a gift.
Offline Rubo
  • Bike: 1992 NH 750
« Reply #41 on: May 31, 2016, 10:40:41 PM »
Nice progress
Just a observation your break fluid reservoir looks hmm out in the air and sort of does not flow on the handlebar.
That's what I see sticking out...
regards
Offline Chris R
  • Bike: 93 CB750
« Reply #42 on: June 01, 2016, 09:35:39 AM »
I plan on shortening the hose and fabricating some kind of bracket.
Offline loudsubz
  • Bike: 1991 CB750
« Reply #43 on: June 01, 2016, 01:38:21 PM »
I suggest you don't unless you like to replace your pipes sooner than later. They trap the heat and rust out faster. They look great but don't do anything for longevity.
Offline Chris R
  • Bike: 93 CB750
« Reply #44 on: June 01, 2016, 02:48:17 PM »
Make sure to soak the wrap before you install.  I made the mistake and just lightly sprayed it down with a spray bottle.
Some people say the wrap is good and some say its bad.  Personally I dont think it would do anything.
Offline loudsubz
  • Bike: 1991 CB750
« Reply #45 on: June 02, 2016, 11:37:13 AM »
http://xlforum.net/vbportal/forums/archive/index.php/t-538905.html
Even the manufacturer recommends not to :)
Offline Adventurer
« Reply #46 on: June 05, 2016, 06:04:17 PM »
Wow. Well, that settles it. No wraps for me! Thanks for the Intel.
Offline Chris R
  • Bike: 93 CB750
« Reply #47 on: June 08, 2016, 03:10:22 PM »
You asked for a tip.  Didnt know you wanted the whole shaft.
Offline Chris R
  • Bike: 93 CB750
« Reply #48 on: October 03, 2016, 11:04:25 AM »
Finished the seat.  Not perfect but will work for now.  Will post pics shortly
Offline Chris R
  • Bike: 93 CB750
« Reply #49 on: October 03, 2016, 11:14:32 AM »
